I have a Samsung DVDR100E recorder & a Liteon 5006 all write recorder I have been busting my head trying to use DVD-RW discs on both, when I record in one & then try & play the exact same disc in the other it wont play & both can take -RW discs even Using DVD-R discs it is the same, record on one & it wont play on the other & vice versa, Can someone please help as this is driving me nuts & I dont want to have to buy a recorder for every room in the house.
I wish the Companies that make these recorders would sort themselves out & make them all compatibile.
The only almost sure way to record with one brand of recorder and play in another is to record video-mode DVD-RW or DVD-R and to finalize the disc. It sounds like you have not finalized the discs. You can still erase a DVD-RW after it has been finalized.
I thought that once the disc was finalized that was it you couldnt record on it, Oh well if thats the case Thank you I will try that & let you know how I get on.
Thanks. -
I probably should add that there are two ways I can re-use a finalized DVD-RW with my Pioneer recorder. One is to unfinalize the disc and then erase the titles that are recorded to it; and the other way is to simply reinitialize the disc (which does not require unfinalizing). I'm guessing you can do the same with your Samsung recorder.
are all dvd recorders rubbish or is it me
By postie1392 in forum DVD & Blu-ray RecordersReplies: 81Last Post: 26th Jun 2017, 17:03 -
Current DVD Recorders available?????
By Regor21 in forum Newbie / General discussionsReplies: 27Last Post: 22nd Jan 2012, 09:43 -
DVD Recorders
By Dragoan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Mar 2010, 11:19 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 11:27 -
DVD recorders/ harddrive ????
By Tom81 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 2nd Oct 2007, 19:52
