Every time I try to author a VBR encoded clip with TDA, it reads the file's maximum bitrate instead of the average bitrate and consquently, authors the file too large for a 4.37 GB DVD. Any way to fix this?
Example: If I have a file that is VBR encoded and the avg bitrate is 6000 and max is 8000, TDA will show the clip's bitrate at 8000.
Been using CBR as workaround so that my bitrates are accurately shown, but want to use VBR. Using TMPGenc as my encoder.
Yes, I've had files 1-2 GB in size and TDA will say they are too large for a 4.37 blank....figuring this to be a false reading I go ahead and author, then when I go to burn w/ the burning tool...won't fit...arrgh! Also I have heard 10080 as max combined and 9800 as max combined which is it?
ImageMixer 3 crashes consistantly!
By joseph7384 in forum Newbie / General discussionsReplies: 9Last Post: 23rd Oct 2011, 10:13 -
File Sizes
By rhodellf in forum Newbie / General discussionsReplies: 7Last Post: 18th Jun 2009, 12:51 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04 -
Different sizes reported for same file
By Richkut in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2007, 15:45
