On 2001-06-22 20:54:02, tuan711 wrote:
I have just started using AVISYNTH with Premiere. After the AVISYNTH window pop-up, use you encoder and open up the part0.avs. I don't know the specific, but I think this is kinda like a hand-shake file from Premiere to your Encoder.
For me I used TMPGEnc to open up the part0.avs file. I don't know if you can change it, but AVISYNTH always saved this under C:\.
After you open up part0.avs with your encoder and press start then the actual encoding begins.
For me, AVISYNTH is useful because I now don't have to export to AVI from Premiere and then convert to Mpeg1/2 in a separate process. Go to the CONVERT section of VCDHELP and click on <FrameServe> for more info.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
When I try opening part0.avs in TMPGEnc, it says "File C:\part0.avs can not open, or unsupported" - does anyone know why?
Results 1 to 1 of 1
How to fix a loose s-video plug
By themaster1 in forum RestorationReplies: 17Last Post: 6th Feb 2011, 01:19 -
What is this plug??
By trunksu in forum Newbie / General discussionsReplies: 3Last Post: 1st Feb 2011, 05:09 -
Steve Thomson VST plug-in
By toneystone in forum AudioReplies: 2Last Post: 8th Dec 2008, 09:58 -
MS Media Player plug-in
By AndreL in forum Software PlayingReplies: 1Last Post: 7th Jun 2008, 16:01 -
Problem with NeatVideo plug-in...
By beckmen in forum RestorationReplies: 0Last Post: 10th Mar 2008, 18:50
