Has anyone out there had problems getting Adobe Encore to work properly?
I have had "Out of Memory" error messages every time I try to use this program. My pc specs are listed in my profile, but briefly I have approx. 50gig free harddrive space and running 512ram. I am trying to author a mulitple chapter DVD of Michael Palin's Sahara series(recorded off digital Tv) with motion menus. I already have TMPGEnc and DVD Architect, but would like to learn Encore. Any ideas??
Burn Baby Burn!
Use Encore 1.5, its more stable.
Encore 1.0 was more of a Beta than a stable release. Unfortunately. If you just bought it I would see if you could get it exchanged for 1.5. I had nothing but headaches with 1.0
Besides that. Where exactly in the process in creating you disc do you get the out of Memory problem. There was a dozen work around for all kinds of problems.Use your head, Side Step the Traps, Snake through the chaos with a SmoothNoodleMaps -
1.0 has a dreadful error that comes up, exhorting you to re-save the project "once" as an "error has occurred".
This doesn't work. Several moments after the new "save", the project may disappear, and the "saved" version never works!
People were pulling their hair out over 1.0 -
Thanks dcsos, I think I will ditch Encore! Seems like too much trouble to bother
Burn Baby Burn!
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 20:24 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
