hey im getting this error in virtualdubmod and i dont know how to fix it.
some help please and thank you's
It isn't an error per say and cutting the frames won't make any difference since it is generated by the decoder and isn't actually part of the stream.
Updating XviD won't fix the problem, however from recollection for some time now a purely black frame instead of the message has been used.
As said using directshow will fix it since the problem is VfW which simply isn't designed to handle advanced stuff like bframes.
Basically if you don't want the lag frame you need to encode with packed bitstream enabled in future or just don't use bframes.
Lag when watching HD
By jester5120 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 18:43 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 19:44 -
virtualdubmod bframe decoder lag
By Szymus in forum Newbie / General discussionsReplies: 8Last Post: 29th Aug 2008, 12:30 -
video seems to lag
By weeleong87 in forum Newbie / General discussionsReplies: 5Last Post: 15th Oct 2007, 07:43 -
B-Frame decoder lag
By demonwarrior in forum Newbie / General discussionsReplies: 0Last Post: 13th Sep 2007, 02:09
