Hi,
I have this weird problem.
My Sony DV camcorder's warranty is about to expire in few days.
Once I had problem with my camcorderr (they cleaned the heads and did soething vith the mysterious "serv" mechanism to solve the problem).
Now everything seems OK, but looking at my last 4 videos I see interesting thing. On 2 of them there is weird bar pulsating at the top of the video. If I deinterlace the video this "bar' doesnt't disappear. I thought that the camcorder is broken, but if you put my last 4 videos in order it goes like this:
video number 1 there is a bar
video number 2 there is no bar
video number 3 there is no bar
video number 4 there is a bar
You may say that maybe there is something with the tape. But all 4 videos were recorded on the same tape.
Any clues?
This video was recorded just few minutes ago. Everything is OK here.
This video sucks. There is that weird bar at the top. Maybe it's hard to notice on static picture but it is noticable on video.
Results 1 to 10 of 10
Hi kb1985,
If your footage is destined to be watched on TV, there's a very good chance that you won't be able to see the "weird bar" as it'll be in the overscan area (i.e. behind the black seal that holds the screen in place).
I know that this doesn't fix your problem, but if it's not gonna be an issue then why worry about it?
I have had the same thing on a DV cam of mine, and it's not viewable on the TV. And, if it's any consolation, the issue has never got any worse - i.e. the DV cam is still OK.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
On the TV this bar is overscanned. But that's not the solution because I'd like to distribute my videos in xvid.
This overscan is another problem because I've just authored one of my first DVD's yesterday and part of the video is not visible on the TV. That's good because there is no bar, but i loose some important parts of the footage. Is there any way to cope with this overscanning before authoring (besides resizing the footage)? -
Does this bar appear if you connect your camcorder directly to the TV/monitor, or does it show up only on the AVI capture? Does it show up in the camcorder's viewfinder/display?
How are you connecting the camcorder to the PC (Firewire?). Wiggle the cable while capturing and see if the bar comes and goes. Check you cables and if possible try a different one. -
No. Overscan is a property of all standard definition televisions -- except for some special studio and medical monitors.Originally Posted by kb1985
I will check on this one when I return home.Originally Posted by Snakebyte1
so, i just have to be careful while making credits or title screen for my video?Originally Posted by junkmalle
Yes. For text you should avoid ~10 percent on all four sides. Here's a good reference:Originally Posted by kb1985
http://scanline.ca/overscan/
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59 -
What are the top "photo and video to dvd" creation tools?
By extent in forum Newbie / General discussionsReplies: 69Last Post: 8th Sep 2010, 18:04 -
Setting "top field first" flag without re-encoding/re-authoring
By Miles in forum Authoring (DVD)Replies: 2Last Post: 16th Jan 2009, 07:15 -
Philips DVP 3140: Annoying black bar after pressing "play"
By tt-jones in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Sep 2007, 23:29 -
VCR Overscan Issues ("jittery" line at top of screen)
By jcm0320 in forum Capturing and VCRReplies: 14Last Post: 24th Aug 2007, 14:56
