Hello,
I am new to the video game and have a couple of basic questions.
I have been using Sonic MyDVD to capture some old analog VHS tapes to my computer by pass through on my Sony HC40 camera. Not much of a problem but I am confused about a couple of points. On the capture screen the questions are ask: "Create Chapter Points" and "Add Clip to Menu". I am not sure what the correct answers should be. If I create chapter points, of 5 minutes, the capture program breaks the capture into 5 minute segments which I assume would make it easier to find a particular segment to edit. I will be doing little or no editing. Should I not create chapter points? What is the advantage or disadvantage of creating chapter points? As far as Add Clip to Menu I don't have a clue what this does and don't know if I should check this box or not.
Any clarification you can offer would be greatly appreciated.
Chapters is just that - points in your final DVD movie that you can jump to. (Using the remote.)
Add clip to menu, must mean that the clip gets a menu item created automatically in the DVD menu system.
/Mats
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 10:21 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 19:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 11:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 14:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 21:33
