I added the program "VanRed" to the sticky (complete list of apps to get you started).
VanRed (eVaporate and Reauthor DVDs) is an application which makes it possible to copy the main movie from a DVD to your hard disc and which allows you to remove certain audio and subtitle streams and evaporates (requant) if necessary the video stream.
http://sourceforge.net/projects/charemma
In order to run VanRed one needs in addition the following piece of software:
- libdvdread from the ogle project: http://www.dtek.chalmers.se/groups/dvd/
- dvdauthor: http://dvdauthor.sourceforge.net/
- vamps and play_cell since version 0.97: http://sourceforge.net/projects/vamps
According to the author:
I failed to install VanRed on SuSE-9.3, as it only has gcc-3.3.5/gcc-c++3.3.5. However it successfully compiles on SuSE-10.0 which has 4.0.2_200509-1-3."vanred is developed in c++ and tested with the following g++ versions:
g++-3.4
g++-4.0
Actually only libdvdread, vamps, play_cell and dvdauthor are really needed to use vanred. lsdvd and streamanalyze are not needed. libdvdcss is only needed to backup encrypted dvds..."
Results 1 to 1 of 1
Could ATSC tuner be added to an old DVD recorder?
By yumagah in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Feb 2009, 17:11 -
idx/sub/sup problem when to be added to dvd
By StarX in forum SubtitleReplies: 4Last Post: 20th Jan 2009, 00:34 -
Possible tool from jdobbs for blueray to dvd5/9 avchd backup.
By freebird73717 in forum Blu-ray RippingReplies: 12Last Post: 30th Sep 2008, 03:18 -
DVD Recorder that allows digital channels to be added?
By VideoJockey2002 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th May 2008, 18:58 -
Can Audio Be added to DVD Menus?
By Scav2003 in forum Authoring (DVD)Replies: 2Last Post: 4th Apr 2008, 17:59
