hi to all
i download a moive and convert it with winavi to dvd (vobs)then i took all the files in the VIDEO_TS folder and put them in nero express(DVD files) section then burned them and tried to play on DVD player and nothin... on the player but (playback prohibited by area limitations)
hi too all i need some hlep.
tell me what more do i have to do to get them on a dvd and play on my dvdplayer??
Results 1 to 9 of 9
Jason.R
Probably a PAL source -> PAL DVD on a NTSC player (or the other way around).
If that's the case, look around here for guides on PAL -> NTSC conversions. There are several methods.
/Mats -
If I have a video file from a unknown source, I drop it into Gspot first and check the video and audio before I try to convert it. PAL should show up as 25fps video. You want to watch for AC3 and MP3 VBR audio also. They can cause problems if not handled properly when converted to DVD format. You can compare the other attributes of the file to the DVD specs in 'What is' DVD to the upper left. <<<
Look here for screenshot posting tips: https://www.videohelp.com/forum/viewtopic.php?t=271697
Anyway, if it shows 25fps, mats.hogberg probably had the answer.
look at this:
Gspot:
Strem Type and A/v interleave
tyep
penDMLAVI IMRR:0.35
IL : 1 and frame(25ms) P=496 split:no
Stream codec
1 name 0x0055(mp3)ID'd as MPEG-1 lay
Video path: (s) avi splitter xvid mpeg-4video decoder (r)Jason.R -
Still no relevant info. Frame rate. What's the frame rate? What TV system where you live?
/Mats -
I'll try again:
Please read
If in doubt, Google it.
burned DVD out of Sync
By agent222 in forum Video ConversionReplies: 11Last Post: 23rd Apr 2012, 00:41 -
i just burned a dvd?
By just in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2008, 22:41 -
Burned Dvd a little choppy?
By kerouacknew in forum MacReplies: 7Last Post: 1st May 2008, 03:43 -
Burned DVD's Out of Sync
By RailheaD in forum AudioReplies: 43Last Post: 11th Dec 2007, 11:09 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
