I converted a set of movies with switchable subtitles last night. It was first season of a tv series and i wanted the episodes to go on one dvd. I created menus and all with dvdstyler. The conversion finished and the folder I created everything in is loaded full of files. Here is a screenshot to give you a better idea of what I'm working with. Does anyone know what I have to do now? Usually when I burn dvd's they come out in a VideoTS folder but I assume there is an additional step here that I'm missing. Also, I loaded in 2 subtitle files but i only see one.
Did you tick Author Disc and / or create DVD image in the Authoring tab of the configuration if not there is your reason
Also there is a problem with spumux if you are using DIKO free 2.12 download a good version HERE
Unzip and overwrite the original spumux.exe that will be in the dvdauthor folder under the DIKO installation folder.
Also duuble click your dvd.xml file will open with IE or whatever your default browser is and see if any errors in there.
If this fails post you log.txt and will try and help more
also there is a bug in the authoring stage that does not like white spaces in the filenames (looks like white spaces in you're filenames) or paths so is also another thing to check
Of course you could just author manually now with an authoring program -
hmm...i tried out the fixes and everything worked but i got errors when i tried burning the dvd....it ended up playing on my dvd player anyways BUT it didn't include both subtitles or the menu so I'm gonna go ahead and try and different program
Question about DIKO
By Belfour in forum Authoring (DVD)Replies: 7Last Post: 6th Aug 2008, 02:27 -
Getting lag spikes when playing converted movies on DVD player
By andre477 in forum Video ConversionReplies: 2Last Post: 13th May 2008, 02:18 -
Burn Already converted MPEG Movies To DVD
By killagoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2008, 21:11 -
toast not accepting some movies converted to pal as is
By jboyd in forum ffmpegX general discussionReplies: 4Last Post: 24th Jan 2008, 20:10 -
Converted analog film movies to BMP/JPG: now to AVI and then DVD
By Wimpie44 in forum Newbie / General discussionsReplies: 13Last Post: 1st Jul 2007, 13:47
