I have a 26G AVI (Panasonic Codec) that I transferred from MiniDV (type 2) and edited down to 22G in Vegas... after edit audio and video are IN synch even in multiple applications. After encoding in TMPGenc 3.0 XPress the audio starts to get off around 3/4 of the way through the 1 hour and 45 min mpeg. It's not off by much, but just enough to be noticeable (fraction of a second). Any solutions to fix or do I have to change some settings and re-encode; I went with mostly 'defaults' in the encode process.
Also, on a 1.8Ghz Pentium, should it take 9-10 hours to encode?
Thanks!
Matt
Try just reencoding the audio after the edit, then mux it back into the video during authoring. (Assuming you are wanting to end up with a DVD.)
That encoding time may be alright, depends on your settings. During that long of an encode, something in the computer may have interrupted the process for a short period. -
Thanks Redwudz!
I found out that even though all the other apps played the a/v out of sync, they were actually in sync when viewed in XPress and acutally burned in sync.Matt
audio and video not in synch by a second or two problem
By sabathiel in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2011, 22:45 -
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 22:59 -
Video and audio are out of synch when authored
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Dec 2009, 00:39 -
Video/Audio synch problem
By tangomango in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 13:19 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47
