This is high definition.
http://www.eetimes.com/news/latest/showArticle.jhtml?articleID=173402762
Results 1 to 13 of 13
NHK developed a Super Hi-Vision camera equipped with 8 megapixel CCD image sensors that can take 4k x 8k images. In the field test, it sent the two cameras to a sea park and sent baseband signals without image compression using an fiberoptic network formed by multiple network companies.
At one point you have to ask yourself how much detail you need to see.....
btw, aren't satellite cameras high resolution? -
Originally Posted by handyguy
I was stunned at how good a decent 1080i show looks. The nature stuff is like looking through a window. Some confuse my cats.
The only thing better would be a walkthrough holo-tank. Something you can pause and stroll through various angles as if you were in the room.
Is it live or memorex? -
Originally Posted by handyguy"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
24 gigabits per second, Japan is way out there just like they were with Hi-Vision analog HDTV in the late 80's.
http://www.kiva.org/about -
Maybe this camera is what they use for that new Ultra High Def screen, that I read about. Apparently the images were so life-like and clear, it made some people motion-sick. I think it was called UHD TV.
What did George Lucas use on Star Wars new films? I know he used high definition digital cameras, but I think I remember reading it wasn't that high of definiton. Certainly not enough for big screen. I remember seeing the first two new Star Wars on big screen, and thought that several scenes looked a little blurry. -
Originally Posted by Wile_E
Some links:
http://www.starwars.com/episode-iii/bts/production/news20030407.html
http://www.studiodaily.com/filmandvideo/searchlist/4413.html
http://www.videotechnology.com/old0604.html
http://www.hollywooddi.com/facilities/hdcamsr.htmlRecommends: Kiva.org - Loans that change lives.
wish I was going to be around for the time they have technology that make you think your actually there
What does it mean to composite elements into the higher resolution digital film? They took the live actors from the 1920x1080 and placed them onto the 4000x2000 and added CGI at that point?
Graphics techniques like static matte paintings are used to turn a 1920x1080 camera shot into a full screen 4000x2000 expansive scene. CGI and other elements are composited on in many layers.
Alpha controls the compositing. Ultimatte creates the alpha from the green screen. CGI is all RGBA at various sizes up to 4000x2000. In film, a separate reel of film called the matte reel provides the equivalent of alpha.
http://www.avid.com/community/post/workflows/workflow.shtmlRecommends: Kiva.org - Loans that change lives.
Yep, i said that way back when HD came around....
How much better can you get than in front of your eye's live 8)
Actual live holograms you can touch and interact with :P
Appropriate pixels?
By bsuska in forum Authoring (Blu-ray)Replies: 52Last Post: 20th Oct 2010, 08:33 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 02:56 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 10:20 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 08:29
