Right so I have some dvd mpg 2 files, they are playable in WMP but when I skip a part it will pause and lag and all that stuff. It will play as if it was being fast forwarded or something. the file is NOT corrupt because it works in powerdvd however I would like to fix it in wmp as well, I got the sticky mpg2 codec installed.
An other problem is with some home vcd files that I made, when I made them they were working and now I reformatted and they're not working anymore. I ran them thru gspot and it says I have the codecs installed. Ideas ? Also I installed WM9Codecs a codec pack for WMP and I'm still having some problems with a bunch of .wmv files being GREEN.
Do you get the same results in Media Player Classic or the VLC player?
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Fascinating. Did these files play correctly before the installation of the codec pack? These "packs" are often the cause of many problems.
Were the VCD standard? Standard VCD use MPG1, the codec for which is built-in to windows and has been for many years. -
Hmm Forum the play fine in MPC, I dunno why they're not playing in WMP like they used to.
Nelson the files had the same problem before I installed the codec pack so its not that and yes it is standard mpg1.
Another thing I'm not sure what codec I had before I formatted but when I played a divx in WMP the words DIVX didn't show in the lower right corner. Any idea?
Missing Codec?
By jimbb in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2011, 14:54 -
wmv missing codec
By uglijimus in forum Video ConversionReplies: 4Last Post: 11th Jul 2009, 01:20 -
Missing a codec?
By jnojr in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2008, 17:24 -
Codec missing
By breeze9 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2008, 21:08 -
Missing Codec
By arileysr2 in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 13:13
