What do I need to convert my hi def output into a vga male for my to hook my monitor up to..
Thanks!
What kind of "hi def output" ?
http://www.kiva.org/about -
its a hi-def output from an xbox 360, regular 6 hdtv rca cables..
X-Box to VGA would be a kludge. The X-box is not intended to work with a RGBHV display.
Get a HDTV instead.
See this thread - https://www.videohelp.com/forum/viewtopic.php?t=284335&highlight=
"converter boxes" should be evaluated carefully. They may work but I'd be suspicious unless checked against reviews and user feedback.
http://www.x2vga.com/Recommends: Kiva.org - Loans that change lives.
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
PC VGA to VGA on LG 42" Plasma
By Squirralien in forum Media Center PC / MediaCentersReplies: 3Last Post: 8th Nov 2008, 20:43 -
laptop with only VGA to VGA-less HDTV
By liiam in forum DVB / IPTVReplies: 0Last Post: 16th Oct 2008, 14:16 -
How may I record in High Def and Playback in High Def ?
By MacPCConsultants in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jun 2008, 16:28 -
Hi-Def???
By ViRaL1 in forum Off topicReplies: 2Last Post: 9th Nov 2007, 08:17
