i bought a belkin wireless router set it to default but can onlyget abot 40kbs instead of the 2mb on my adsl modem. Can someone tell me where I am going wrong as I also have a phillips wireless media centre which I cant use properly.
Any ideas
Thanx
What first comes to mind is how far are you from the router, are there a lot of walls, and is there a lot of metal between you and the router.
All these can impair the signal.
Also, a 2.4 GHz cordless phone can have a detrimental affect as well.
Are you using 802.11b or 802.11g wireless? G is significantly better than B when it comes to range and transmission speeds. 54 Mps for G as opposed to 11 Mps for B.TANSTAAFL -
Right. As long as your signal isn't horrible between the computer and the router its not a wireless problem 9 times out of 10. How fast is your 2mb adsl plugged directly into the router via a cable?
This may seem obvious, but be very sure to read the book that came with your router. My wireless router had some odd quirks that gave detrimental results used wrongly. I read the book and had no problems after that.
I have a "B" router for my ancient laptop, but it works great, even through about 6 walls 100 feet or more away. Through a cordless phone on one of the walls too. Could be good luck, but either way, it works fine.Want my help? Ask here! (not via PM!)
It is right above the pc it is also g do I need to change the ip address to my broadband provider as is set at default at moment.
Most wireless routers have RJ45 jacks in the back for a wired connection. Why aren't you using that? I would. You get a faster and much more reliable connection.
TANSTAAFL -
Yeah if its right by the router then quoted for extra truth.Originally Posted by Prot
Try plugging modem directly into PC and test speed. Also test with wired connection on router and test speed.
Unless you have some ungodly kind of interference the wireless part should not be a problem.
Some G series wireless routers have problems if WEP is turned on.
Wireless N Router
By mccoady in forum ComputerReplies: 5Last Post: 17th Jun 2010, 15:38 -
Wireless Router Help!
By Nitro89 in forum ComputerReplies: 8Last Post: 10th Feb 2008, 05:22 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
which wireless router should i get?
By Ade007 in forum ComputerReplies: 11Last Post: 2nd Jul 2007, 08:05
