I don't know if this trick works on ALL HD Res material, but it runs perfectly on my 720p and 1080i Mpeg2 files. It plays back in 1/2 size as the original, but for slow machines (<3Ghz) , it will do the trick![]()
Download a recent copy of Mplayer
http://ffdshow.faireal.net/mirror/mplayer/
from the command line (or, you can save this as a batch file)
mplayer -vc ffmpeg12 -lavdopts lowres=1 filename.mpg
If you want to get fancy, save the following line as Play.bat
mplayer -vc ffmpeg12 -lavdopts lowres=1 %1
Then from the command line, you can always run
Play myfile.mpg
* The Mplayer Syntax was snagged from an old Doom9 post. Props to the originator *
I have always found that the best way to playback MPEG-2 HDTV files, is to set MPlayer, or Zoom Player to use the Cyberlink DTV Codec, and using the filter properties options, enable video acceleration. If you have a video card with DxVA, you will notice a huge difference. I get around 90-100% cpu usage without it enabled, and 40% with video acceleration enabled . I have a 2.4GHz processor btw. The great think about using this method is you get to watch HDTV at full resolution.
Absolutely, but when you only have a FX5200 card like myself, the choices are limited. I wouldn't necessarily recommend running everything and at all times in half res, but rather, think of it as an easy way to preview footage while your system is busy doing other things (recording, etc).
I used to be able to play full resolution with Fusion HDTV, at Medium level quality, but recently it has been forcing me to use the Normal quality level. If I use the Medium or High I just get a crapped out jumbled picture. Kinda sucks. I haven't changed anything that I know of lately. I have a Barton 2500+ and OnBoard video for a Shuttle XPC. I hate to have to upgrade, maybe just a new AGP video card until I am forced to go PCI-E.
No previews with PROCODER3 under Windows 7
By IMASBLUE in forum Newbie / General discussionsReplies: 0Last Post: 8th Feb 2012, 06:19 -
How do I configure MPC-HC for jitter-/stutterless playback?
By Stealth3si in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2011, 16:32 -
How to remove previews?
By maverickluke in forum DVD RippingReplies: 6Last Post: 20th Mar 2009, 22:44 -
No Previews 8(
By palnudb in forum ffmpegX general discussionReplies: 2Last Post: 14th Jan 2008, 10:36 -
No MPG Thumbnail Previews
By LennytheFerret in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 9th Sep 2007, 10:42
