i have 2 files , one is an mpeg and one is avi . when i encode them with tmpegnc plus i use full screen (keep aspect ratio) and my picture comes out ok , except it is squashed on the sides. top to bottom is fine, it's just the sides. anybody knows how to fix this.......
Did you choose 4:3 or 16:9 as your source material? That can make a difference. Also try "keep aspect ratio 2" sometimes that makes a difference.
If its tv captured stuff use 4:3 otherwise if its dvd rip use 16:9 as most of them are that way (though tv shows on dvd and older movies often are 4:3 not 16:9).
Also try editing out a small clip from the main file and experiment with the settings on that. That way you get really quick results and can write down the settings that work without waiting for an entire movie to encode.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Squashed ffmpegx Flash Video in iWeb
By IrishP in forum ffmpegX general discussionReplies: 10Last Post: 20th Jun 2011, 09:32 -
SONY DVP-SR700H - squashed DivX picture
By jhrebacka in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2010, 11:21 -
Squashed picture/removing the fake black bar?
By Joolz2020 in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 07:56 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
Streaming Video with vista 64bit Squashed! HELP!!!!!!!!!!!!
By dking in forum Video Streaming DownloadingReplies: 1Last Post: 21st Jul 2009, 14:17
