I have two firewire devices: 1 Sony DVD Burner and 1 Dazzle Hollywood
Bridge (analog/digital converter).
The Sony DVD works ok in both firewire ports and System Profiler
(Firewire) shows the hardware, but I can't see the Dazzle in System
Profiler.
There's a message int the system log:
"iMac-G5 kernel[0]: FireWire (OHCI) Apple ID 52 built-in: 360 bus
resets in last minute."
I connected the Dazzle other Mac (ibook with tiger too) and the System
Profiler shows "Dazzle Hollywood" and it works ok!
Please help me!
It sounds like you have a system software issue. Check macfixit.com for reports of Firewire issues and how to fix them. One oftentimes-effective step is to download and apply the latest combined system updater from Apple. Be sure to have all Firewire devices disconnected when applying the updater.
which version of Tiger?
iMac and Firewire issues :
Devices that draw power through the FW ports
( I suspect your Dazzle does?)
can cause theFW ports to act like you describe:
I have seen this first hand with FW iSight Cameras.
Best solution is to get a FW (wall powered) HUB,
like the Belkin or the MacAlly ones.
Plug the Dazzle into that, and then plug the hub
into the iMac. Should then recognize it correctly.
iMac G5 FW"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I'm using 10.4.3 now, but the problem is since 10.4.2. I tried to restart FW ports, PRAM, NVRAM etc etc etc without success.
Maybe if I reformat and re-install Tiger? What do you think?
Thanks. -
Reformating will only prove time consuming and ultimately not solve your problem. The firewire hub will.
Thanks willrob, I was going to suggest that.
Urban Mac User
software for an imac
By marlo in forum MacReplies: 11Last Post: 13th Aug 2011, 09:49 -
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 13:30 -
DirecTV HD to iMac?
By jcoconnor in forum MacReplies: 0Last Post: 5th Apr 2009, 16:36 -
Dell or imac
By fairytale00 in forum ComputerReplies: 17Last Post: 29th Mar 2008, 13:51 -
Problem with imac G4
By matw79 in forum MacReplies: 1Last Post: 14th Jul 2007, 07:55
