I just finished transferring some home videos to my PC and used DVD Workshop 2 to author a DVD. The DVD plays fine on my stand alone DVD player. However, on my HTPC, I can hear sound on the menus but not on the actual video footage. The stand alone sound is connected via RCA cables and the HTPC with a digital optical connection.
Can someone verify this and tell me what settings to use in the future so that the sound will play on all? Im assuming I authored the DVD with the wrong sound format. Also, how would I go about stripping the sound out of the dvd, changing it to a compliant type, and then re-authoring the dvd?
THANKS!!
I don't think you can author a disc with the wrong foramt using DVDWS, it won't allow it. There really is no wrong selection, usually playback issues arise when you use mpeg audio but that only pertains to playback on some NTSC standalone DVD players. Generally computer playback is not a problem.......Originally Posted by kevbach
If it plays in your standalone I think it's safe to say you have used a compliant format.
Most likely you have a codec issue, what format did you use? -
As the HTPC uses digital optical, maybe you left the sound at the default setting of LPCM and not AC3. AC3 will be ouitput on an optical output, LPCM may not.
Can I create my own custom Button in TMPGEnc Authoring Workshop 4?
By JackyWang in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2016, 23:14 -
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
authoring program with dts sound
By tommcd64 in forum Authoring (DVD)Replies: 3Last Post: 25th Feb 2008, 13:59 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 10:16
