  1. Member underwurlde's Avatar
    May 2004
    S.England
    Been a while, so hello all!
    I have recently 'discovered' the wonders & simplicity of DVD Remake after reading many good things said about it. After a bit of experimenting with it I have what I hope is a simple question:
    When I use DVD Remake to merge two (or more) DVDs to one, it creates for you a standard first play select menu. This menu (as many of you no doubt already know) is based on a default menu asking you to select and play either 'Disk 1' or 'Disk 2' etc. with a bogey green background image that includes the DVD Remake logo.
    My question is this: Once I have exported & created my merged DVD using Remake, how can I reauthor this intro disk select menu - is this even possible. What I'm aiming for is a background image of my own choice, highlightable text / images of my own choice that link as per the original Remake disk select menu. I'm looking for a program that is as simple to use DVD Lab Pro.
    Infact some of you may come back and hopefully tell me that I can indeed use DVD Lab Pro or TMPG DVD Author - but if so how & what are the pitfalls?
    Any advice on best programs to use greatly appreciated.
    Thanks in advance,
    Andy
    Work you bloody thing....
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yep. IIRC there's a guide on the website ...
    http://www.dimadsoft.com/dvdremakepro/ht_customize_menu.php
    I've got a feeling that you create your menu as you would like in TDA or DVD-lab and then import it into DVDRemake and replace all the links and commands to what you need them to be.
    If in doubt, Google it.
  3. Member underwurlde's Avatar
    May 2004
    S.England
    Hi Jim
    Nice to see you're still a major contributor to this forum!
    Good answer to my question, exactly what I was looking for so many thanks for that, mucho appreciated.
    Can anyone suggest a good program that can be used to create these so called dummy single menu item DVDs?
    Cheers,
    Andy
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    stiltman and MackemX had a few trials with it here:
    https://www.videohelp.com/forum/viewtopic.php?p=1147374#1147374
    https://www.videohelp.com/forum/viewtopic.php?p=1142524#1142524
    That mentions TDA, but I believe you can use any authoring program to create your menu, as all you need is the VIDEO_TS.VOB file it creates.
  5. also make sure you are uisng dvdremakepro and NOT the smaller dvdremake. The Pro adds/has many more features than the regular version
  6. Member underwurlde's Avatar
    May 2004
    S.England
    Hello,
    Thanks! Forum member's prompt responses have proved bang on again.
    A year since using this site & it still absolutely ROCKS.
    Andy.
