Hey guys/gals, I have a quick question. I have done a search and overwhelmed myself with the information provided and I am no closer to a solution than before I started! Basically, I am after a simple animation tool that can save files in avi format. What I am trying to do is to make a short animated movie for my young son. I am not trying to do a 'Finding Nemo' type of animation. All I want is simple smily faces on screen where I can animate their mouths so they can tell jokes/riddles. I need avi format because I am lucky enough (?) to have Adobe Premier at home and I was going to use my camcorder to record the voices for the jokes and then just lay them over the talking faces. Then I was going to burn them on DVD and send them to him.
Cheers.
Have a look here, might be of some use to you -
https://www.videohelp.com/forum/viewtopic.php?t=284269&highlight=animationHe's a liar and a murderer, and I say that with all due respect. -
You can record directly to your HDD or editor.Originally Posted by MadMaz
I'm not familiar with Premeir but it should have a voice overlay feature, just load the clip into premeire, plug a mic into your computer and record as the video is playing.
This is used for adding commentary it correctly matches up with video, otherwise it would be a nightmare getting good sync.
If not just go to start>accessories>entertainment>sound recorder. Adjust the sound recording settings to a DVD compliant spec.
Free simple tool to export sections of videos?
By Maoukiji in forum Newbie / General discussionsReplies: 6Last Post: 19th Mar 2012, 13:59 -
simple freeware tool
By agent222 in forum Video ConversionReplies: 3Last Post: 1st Oct 2010, 16:22 -
Simple wmv editing tool
By karebo in forum EditingReplies: 2Last Post: 5th Apr 2010, 05:40 -
What IDE to use to create a simple GUI for command line tool?
By freebird73717 in forum ProgrammingReplies: 10Last Post: 5th Nov 2007, 14:51 -
Simple tool for Noise Reduction, Wind, Waves, etc
By Etherel15 in forum RestorationReplies: 1Last Post: 8th Jun 2007, 03:09
