Hello,
Can someone point me to some encoder which will produce the best result to encode from VCD to DVD.
I have used SVCD2DVD to make a dvd from several VCD cd's by renaming the DAT files to mpg and it works ok. But I would like to know if there are better results attainable for the encoding only.
Regards
Dooku
It's pointless. VCD resolution is part of the DVD specs, all you need to do is change the audio from 44,000 to 48,000.
He's a liar and a murderer, and I say that with all due respect.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 09:09 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41 -
DVD Encoder to shrink D9 to D5
By 3lutz3toe in forum MacReplies: 1Last Post: 23rd Sep 2009, 16:22
