i have some shows that have the intro and outro encoded onto them. what i would like to do is encode them and then cut out the intro and outro. is there a program that will let me specify a time (as it is the same for each episode) to cut at for the beginning. i am not so concerned with cutting out the ending, but rather the intro.
thanks
-Syco54645
i thought about avisynth, but then i would have to cut the audio exact as well, and that is more work than i want to do. if there was a way to do it with avisynth (the audio portion) then i would. but as far as i remember, there is not functionality for mp2 audio, just wav.... which i guess is good enough. the problem is that i use cce to encode and i do not encode the audio with cce. got any good ideas for how to handle the audio?
-Syco54645 -
If you have your audio file as say AC3 and a Mpeg2 file insert them into
Cuttermaran this editor works really well.
Recommend a batch conversion program for mkv to wmv?
By yoda313 in forum Video ConversionReplies: 2Last Post: 23rd May 2009, 07:58 -
automatic or batch processing in Cut Assistant: possible?
By cbarduck in forum EditingReplies: 0Last Post: 9th Feb 2009, 07:11 -
Hi, need a program to batch multiplex.
By mmdmmd in forum AudioReplies: 2Last Post: 18th Oct 2008, 14:50 -
Hi all, I need program to batch de-multiplex mpg files with 2 audio tracks
By mmdmmd in forum AudioReplies: 4Last Post: 14th Oct 2008, 16:57
