Thanks inadvance for any help. I am trying to convert a .wmv to .mpeg to be used with flash. Every time I go to finish the conversion it is done in like half a second, and then when I try to open the file, it sais invalid file. Do I have to tweek certain settings or anything. I am not trying to change the size or anything just a simple conversion.
I am using 9t...
Here is the message from the blue "i" however I am not getting an error message untill I try to play in quicktime for example.
The quicktime error message is :
QuickTime cannot open the file: "Michelle&John_reception.wmv.ff.mov"
it is not a file that QuickTime understands (-2048)
A few users of ffmpegX (myself included) have been reporting that 9t (with the new support files) fails to work for many, if not all, conversions. I reverted back to 9s (which may be found here: http://homepage.mac.com/major4/ffmpegX_0.0.9s.dmg ) and the older set of support files. Works fine now (except for H.264 but this is a known item I've been told).
AoA Audio Extractor Basic, how did i time splitt in it?
By Blå_Mocka in forum AudioReplies: 4Last Post: 5th Apr 2012, 11:22 -
JVC GR-D850u first time user -- transfer to PC
By mister in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th May 2009, 11:33 -
what is the 'DSL' file that seems to appear from time to time on DVD's?
By rotuts in forum MacReplies: 6Last Post: 24th Aug 2008, 14:08 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48 -
various time codes on miniDV. Want one time code.
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 22:08
