I'm converting some video
AVI -> MPEG -> VOB
that has muddy sound since it was recorded on VHS in the 80s. I'd like to crank up the high end of the audio spectrum. Are there some tools that will handle this as part of the transcode? TMpegEnc and WinAVI seem to have none of this.
Tim
Not during the transcode..
You'll have to filter and normalize the sound with a separate .WAV editor.
Once that's done, then encode to your heart's content...
Good luck!! -
You could run it through an audio editor and see if you can make any improvements by filtering adjustments. I use the freeware audio editor Audacity.
I put the AVI into VirtualDub and save out the audio as a WAV. Then import that to Audacity, do your editing and save the output as a WAV. You can then encode to MPEG-2 by using the original video and select the new WAV as your audio source. Other programs can do this also. -
Improving "hollow" sound from a film?
By takearushfan in forum AudioReplies: 14Last Post: 1st Apr 2012, 11:39 -
Improving a noisy sound stream
By Ygramul in forum AudioReplies: 1Last Post: 3rd May 2011, 09:48 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 19:15 -
there's no sound with my mpeg-1 conversion
By darealest1 in forum MacReplies: 1Last Post: 13th Jul 2007, 08:12
