I have a problem where the audio track is bad
virtualdub recommends I should extract the audio track decommpress and recompress
This original audio track is mp3 format
How do I do that and what tools do I need thanks?
virtualdub
open video.
file->save wav
to decompress.
or
goldwave
open avi
save wav
then
virtualdub
open video
audio->wav audio select the wav
audio->compression and select mp3
video->direct stream copy
file->save avi -
Thank you
There is a small problem as explained above it will only allow me to save the new avi file in full processing mode and not direct copy stream whichj makes the file very large -
In VirtualDubMod, if you need to do full processing of the audio, you select the compression, MPEG-3 and the same data rate and sample rate and it 'should' end up the same size as the original. You can use 'Show all formats' for fine tuning. Set the video to direct stream copy only. The audio and video processing can be set separately, if that's what you mean
VD will show you the format info when you open the file and look in 'File Information'.
Repair avi file
By John38837372792 in forum Video ConversionReplies: 2Last Post: 23rd Sep 2011, 15:34 -
Megui audo error
By thezanny in forum Video ConversionReplies: 0Last Post: 7th May 2011, 20:15 -
Other audo for a movie
By philipvanr in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2010, 11:37 -
Repair AVI files
By steviewilson in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2010, 19:32 -
repair deleted AVI
By john_22 in forum Newbie / General discussionsReplies: 6Last Post: 30th Oct 2007, 10:21
