  1. Hi,
    I have been using ZOOTech DVD-Extra to author my DVDs problem is i'm finding it very diffult to operate as I am a total beginner.
    I have compiled my DVD and it works fine, but I was just wondering if there is a program that I can use to rip the DVD so that I can add movie clips on the menus I have already created.
    To explain further I have menus (pages), like the one below, now what I really want instead of the images is a movie.
    Think it can be done? Thanks
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Basically, you have to take the DVD apart, and start over with your source material. It will be simpler than trying to modify your DVD.
    Extract the audio and video you want to keep, and start over.
    /Mats
  3. Well up to now its just menus with text and images on them, I want to add audio and video to it and position it in the gaps I have left for them purposely
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Don't understand a thing - Gaps in what?
    Basically, once you've authored a DVD it's done. Even if it's possible to add stuff, it's much easier to reauthor.
    /Mats
