Hello,
I have some VCD cd's I want to convert to DVD so I can burn a few movies on one dvd.
I have bought SVCD2DVD and have used it only a few times to convert svcd, but I am a bit puzzled now because the VCD cd's contain a few directories:
\CDI
\EXT
\MPEGSAV
\SEGMENT
\VCD
The movie is located in the \MPEGSAV directory and is this file
AVSEQ01.DAT
But SVCD does not recognize DAT files so I can not add this to the asset screen?
Can anyone help me how to go about this?
Regards
Dooku
Well the best way is to extract the mpeg using IsoBuster. Use step One from this guide: https://www.videohelp.com/forum/userguides/159399.php
OR
You can copy the AVSEQ01.DAT file to your hardrive and rename it from .dat to .mpg. SVCD2DVD will then accept it and turn it into a proper mpeg file.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
