Would like to add more memory to my older system. Currently, it's got 512MB of DDR266. Any problem with using DDR400 memory which would be faster whenever I upgrade (new mobo/processor) my system in the future? As a test, I've put in another 512MB of DDR400 from another system I have. Seems to work OK, although I can't see any dramatic increases in system performance. Am I missing something?? Thanks.
wwaag
Well if the CPUs bus speed is 266 and you put 400 in then its going to work at 266. So you have 2 sticks at 266.
You also have to remember that Windows is a picky beast, I've found ram upgrades work fine in apps and games with little effort, but for you to be able to feel it in Windows itself you really got to either clean up the system or reinstall it.
Question on USB Memory Sticks..
By SE14man in forum Newbie / General discussionsReplies: 17Last Post: 15th Feb 2012, 09:57 -
Activation Required on Memory Upgrade?
By bevills1 in forum ComputerReplies: 13Last Post: 27th May 2011, 19:48 -
Memory upgrade question
By zzyzzx in forum ComputerReplies: 12Last Post: 13th Jan 2011, 17:27 -
MKV Question (need memory jogged)
By Maikeru-sama in forum Video ConversionReplies: 5Last Post: 29th Jun 2008, 12:49 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
