Hallo!
I use CDex for CD ripping & converting to MP3.
And i am wondering, is there any difference (in quality) between 'on the fly' encoding or first extracting to .wav and then encode to mp3?
Sorry for my bad English.![]()
In the past (Like, 2001 or something), I used CDEX with an ancient CD-ROM (16X IIRC). On the fly results were generally horrible, as the CD-ROM couldn't supply the data to the MP3 encoder quick enough, and it was much like dropped frames when capping video. There were also a number of clicks, pops etc etc in the MP3s as well. Yet extracting to WAV with CDEX, then encoding the WAVs to MP3 with CDEX produced flawless results.
If in doubt, Google it. -
No reason (unlike capture) why it should need to be realtime though. If the drive can't supply the data realtime then it would just take longer than realtime to encode.
16X isn't ancient. I had a 1X external back in the day.
WMV9 (AP)/MP3 - Cut without re-encoding. Latest options?
By Golem in forum EditingReplies: 2Last Post: 6th Dec 2011, 18:52 -
How can I extract mp3 audio from .mov container without re-encoding?
By Danteism in forum MacReplies: 16Last Post: 3rd Jul 2010, 04:11 -
Encoding Mp3's for use in Flash player
By JohnX in forum ffmpegX general discussionReplies: 1Last Post: 26th Oct 2009, 13:20 -
Looking For MP3 Encoding Software That Has These Features:
By cplevel42 in forum AudioReplies: 15Last Post: 8th Oct 2009, 12:51 -
Encoding MP3 causes the sample length to CHANGE?
By Colmino in forum AudioReplies: 1Last Post: 26th Nov 2007, 20:00
