Are there any TMPGEnc Templates to make VCD PAL (with subtitles) and make a movie around 700mb to burn on 1 CD 700mb/80min?
I try to find one to make my movies and to play on my dvd player (my DVD player can NOT play SVCD) so I can only make VCD PAL!
PLEASE HELP ME to fine a good template!
have you looked under the tools section to the left, if you scroll down there are various tmpgenc templates there.
I particularly like sefy's -
Thanks Tigerwolf!
but now I have to select two SEFY´S templates...the basic or the enhanced SeVCD?
What is the better one? -
Can some one tell me...Are there more Templates?
to fit my movie on singel 700mb/80min? -
Actually every conversion needs a different template.
So create your own one. To fit a movie onto a 80min CD, use a bitrate calculator. Have a look at the tool section.
__________________________________________________ _________________
Merry Christmas. See you next year. -
tigerwolf, thank you for the compliments!
Glock, the diffrence between basic and enhanced, the basic uses lower VBR settings and basicly it's supposed to be less quality and enhanced is more optimized according to information i have gathered on the forums.
Also, SeVCD uses MPEG1 VBR so it's more compatible with DVD's
and the SxVCD uses MPEG2 VBR so try checking to compatible DVD lists that is included.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
templates for Corel VideoStudio X3?
By wingfan in forum EditingReplies: 2Last Post: 25th Feb 2010, 14:10 -
FairUse conversion templates
By herbapou in forum DVD RippingReplies: 1Last Post: 9th Mar 2009, 08:27 -
Tmpgenc Xpress 4 : any PS3 templates?
By lapino in forum Video ConversionReplies: 0Last Post: 12th Mar 2008, 08:34 -
DVD templates
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 01:16 -
DVD Templates and encoding
By Canadian* in forum Authoring (DVD)Replies: 2Last Post: 24th Sep 2007, 18:11
