I'm attempting my 1st motion menu with DVDWS2.. Simple question is this: How do I create the motion clip for the menu??
Is it simple as using something like MPEGVCR to 'cut' the motion scenes (assuming mpg/DVD compliant), then importing them into DVDWS2's video library, then into the menu background i the Menu stage? If so, I think I can handle it.. BUT...
What if I want to use mulitiple scenes/clips that I want to run together seamlessly? How do I join them together or is there an easier way in DVDWS2 to do this.. or.. ?? Any help w/b appreciated.. thanks!
Lastly, in the menu, how the heck do I get a simple still in the thumbnail for chapters? (everytime I create a menu, I keep getting motion thumbnails).. I simply use the auto-add chapters feature for creating chapters (fixed time intervals).
The tittle of your post should have read something like this:
"DVDWS2 and Motion Menus?"
It's been years since I've used DVDWS, so I can't help you with that app specifically. I will tell you that the best way to create a motion menu, is to do it in your Video Editor, then encode to Mpeg before importing into DVD Authoring app.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
Originally Posted by rbatty11
Slow motion at least 1 minute long clips?
By owen bryan in forum Newbie / General discussionsReplies: 4Last Post: 27th Nov 2010, 21:08 -
stills to video speeding up frames/sec or stop motion
By slnorth in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2010, 22:06 -
Virtualdub-like slow motion for x264 clips?
By spinmonk in forum EditingReplies: 15Last Post: 19th Sep 2009, 12:33 -
Motion Menu with custom clips?
By chaosnovaxz in forum Authoring (DVD)Replies: 16Last Post: 14th Jan 2008, 10:49 -
dvdauthor authoring problem (combing 16:9 and 4:3 material)
By ecc in forum Authoring (DVD)Replies: 4Last Post: 5th Jul 2007, 20:14
