I use TMPGEnc DVD Author for authoring DVD, and it works OK on most DVD players, but on some DVD players the "SELECT" button is missing on remote unit, so for start the video only solution is to use "PLAY" button. Play button is used to select the wanted subtitle or audio channel, but is impossible to start the DVD disc authoring with TMPGEnc DVD Author pressing the play button.
At the other hand, at most DVD players is impossible to start the video by pressing the play button. Moving with arrows to desired field (play, subtitle, audio channel) then pressing select button and video is on. So simple but.....
Regards.
QUALITY HAS A NAME
There is a setting for first play in the program? Will this help?
Button command(s) to select audio and subtitles simultaneously
By dexter30 in forum Authoring (DVD)Replies: 1Last Post: 26th Mar 2012, 16:42 -
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 09:21 -
How to select which PID to play in Mpeg2 TS
By deepp in forum ProgrammingReplies: 0Last Post: 9th Jun 2010, 18:52 -
Title Playback Pre & Post Commands, back to menu, select next button
By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2009, 20:24 -
Wont play main title. Stuck at episode select menu
By drashleyj in forum MacReplies: 1Last Post: 13th Mar 2008, 08:19
