Is it possible to frameserve from After Effects?
Or, how to export video to PicVideo or Huffyuv instead only few DV codecs that version 5.5, which I use, allow...
I don't believe you can frameserve from AE. The only plugin frameserver I know is debugmode's excellent tool, however it only supports a range of editor, not AE.
You should be able to export from AE into any AVI codec you have installed. Just select AVI as the output type, and then huffyuv (or whatever) as the codec. Unfortunately I am in the middle of rebuilding my PC, so I don't have AE installed yet to confirm the actual steps for you.Read my blog here.
You must be doing something wrong.
AE (from 3.x onwards) allows you to export to:
AVI, with any of the available Vfw/Directshow codecs that would normally be listed on your machine (I've got ~40 on mine).
QT, with any of the available QT codecs listed on your machine (I've got ~45 on mine).
A number of picture-sequence formats--JPG, TIFF, TGA, BMP, PSD, etc.
Electric Image format
Animated GIF
Adobe Filmstrip format
and a few others...
Scott -
In my After Effects 5.5, when I click to File/Export I choose AVI. Then in dialog named "AVI Settings" I select "Settings..." under Video group.
Then, in "Compression Settings" dialog, here is what I can select:
BMP
Cinepak
DV-PAL
DV/DVCPRO - NTSC
DVCPRO - PAL
Intel Indeo Video 4.4
None
No trace of installed Huffyuv, Picvideo, Divx... and other that I can normally select and use from Premiere...
Where am I wrong? -
Maybe you haven't installed them on that computer!? Those are 3rd party plugins (don't come with Windows or AE).
or, if as you say you can use them in Premiere on the same computer...
Some installation is corrupt and needs to be uninstalled/reinstalled.
I've just checked 4 different machines, no difficulties here.
Scott -
Originally Posted by arminio
You are selecting (Video For Windows"?
In the drop down (Based On Lossless)??
Here you should see Huff. When all the ubove is done Under (Format Options). -
Everything is installed correctly - I see huffyuv, pivcideo, DivX and ton of othr codecs in all applications except AE. I workn on the same PC - ofcourse...
Now, about canadateck tips:
I can select huffyuv and picvideo under "Templates - output module" option. This is only option where all codecs are available. But at the end, when I export, I still have only few codecs to select as I listed in my post (and no huffyuv/Picvideo)...
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
After Effects: copy effects to another composition?
By squadjot in forum EditingReplies: 2Last Post: 8th Dec 2009, 19:16 -
Do I need After Effects?
By hanexs in forum Newbie / General discussionsReplies: 13Last Post: 3rd Feb 2008, 22:06 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
