Hello all,
I've been authoring my DVD's with DVDlab 1.53 it all goes well and the burn fine. Its just that on my standalone DVD player when I play the movie from the start its ok, but when i select a chapter it plays but its very jerky. Anyone know how i can resolve this problem ?
Cheers Jim
What was your source viseo - something you converted yourself, or from another DVD ?
How did you create the source mpegs ?
If it come from another DVD, did you demux when you loaded the vobs ?
Did you frame index in DLP ?
What media did you use ?
If you play the dvd back from the HDD, does it do the same thing ?Read my blog here.
I converted it myself in The Film Machine
I created seperate VIDEO and AC3 files so i could multiplex them in DVDlab
Yes i did mulitplex in DVDLab this was done automatically when authoring DVD (What is frame indexing?)
It was burnt on Datawrite Titanium 8x DVD-R @4x in CopytoDvd
No -
Frame indexing is an option in DLP that lets you place chapter points more accurately than simple I-frames permit. It masically allows you to use frame offsets. It is worth doing.
I know DLP multiplexed for you. What I was looking for was demultiplexing if you had VOB sources. As you had ES source to begin with, you would not have a need to demux.
That all plays well from the HDD suggests the problem is probably media related, but whether or not this is a quality issue or a player compatability issue is harder to call.
A couple of things to try
1. Burn to different media. Maybe try an RW so it's not a wasted disk if it fails
2. Try you first disk on another couple of players to see if the problem is consistent
3. Try burning to another -R at 4x to see if it helps.Read my blog here.
missing chapters on standalone dvd - dvdlab
By lukasz.w80 in forum Authoring (DVD)Replies: 0Last Post: 10th May 2011, 09:56 -
how to rearrange the movies in dvdlab
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2010, 06:18 -
Authoring with DVDLAB 1.3 and chapters get out the farther I go!
By gwoiler in forum Authoring (VCD/SVCD)Replies: 5Last Post: 28th Feb 2010, 17:18 -
DVDlab Compared with TDA
By loster in forum Authoring (DVD)Replies: 7Last Post: 30th Dec 2007, 19:34 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 04:55
