I have a 23GB-dv-folder of citizen kane (imported with a/d converter) on an external hard drive (60GB). Now, if I open it in ffmpegX, set conversion to DVD with either DVDffmpeg or DVDmpeg2enc (to the external drive, again), what I find after the conversion is an .mpv file without sound.
Only days ago I did the same conversion with "twin peaks-fire walk with me", and it worked great (the only difference was another external drive, that I had the .dv file on (Lacie drive with 160GB). Then I had the necessary AUDIO_TS and VIDEO_TS folders created, and the DVD works fine now.
Since I have no idea, what the reason for this strange behaviour could be, please help (I tried about 6 times with different encoding settings, no luck yet).
what could be going on here?
tobias
apple powerbook g4 867Mhz, Yamaha01x Console
apple ibook G3, several Audio Devices
thanks for your response,
it's not a mov, but a dv-folder, with quicktime-thumbnail.
it was created with formacs studio tvr, which, as the manual says, creates dv-format.
what exactly do you mean by "process output"? the output mpv-file is erased. Should I try again to be able to post a picture?apple powerbook g4 867Mhz, Yamaha01x Console
Now here's the process output:
Encoding started on Sat Nov 12 21:03:57 CET 2005
Input #0, dv, from '/Volumes/laughing/citizen kane.dv':
Duration: 01:54:18.6, start: 0.000000, bitrate: 28799 kb/s
Stream #0.0: Video: dvvideo, yuv420p, 720x576, 25.00 fps, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Output #0, rawvideo, to '/Volumes/laughing/citizen kane.dv.ff.mpv':
Stream #0.0: Video: mpeg2video, yuv420p, 720x576, 25.00 fps, q=2-20, 4000 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg2video @ 0x4199e0]rc buffer underflow
[mpeg2video @ 0x4199e0]rc buffer underflowapple powerbook g4 867Mhz, Yamaha01x Console
Thanks again, it worked this time ("encoded with Quicktime").
funny, though, it ended up in three files:
...dv.ff.mpg
...dv.ff.ac3 and
...dv.ff.DVD, containing the necessary folders (AUDIO_TS, VIDEO_TS)
-is that the way it's meant to come out?? (sorry if I sound stupid, I'm still new to ffmpeg)apple powerbook g4 867Mhz, Yamaha01x Console
DVD writer doesn't work
By kamyogi in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Apr 2011, 11:43 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 14:44 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
What am doing wrong ? HD DVD using PowerDVD doesn't work
By NICEBUD in forum Software PlayingReplies: 12Last Post: 5th Nov 2007, 03:28
