I've done lots of frameserving with DVD2AVI, but whenever I used VirtualDub it was simply to make a new .avi with my desired settings. I tried using it tonight to frameserve for the first time, and despite following every guide, making sure I have all necessary files installed, etc, it does... nothing. The little window where it shows the number of frames processed just sits at "0" and there's no activity. Any idea what could be wrong? I've read and re-read the guides posted on this site, and it just won't do anything. I'm using VirtualDub 1.5 and Windows XP. Thanks.
Also tried VirtualDub mod, with the same result.
Well, I'm confused. Normally frameserving does not do anything visible.
You open your encoder and select the .vdr file from the VD frameserver and then it loads the VD file into your encoder. You encode with that.
If you are using frameserving to create a new AVI, you would need an AVI encoder that would accept the frameserve output.Never tried that.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
What VCDHunter and I meant by DVD2AVI "doing something" is that you have to wait a minute or two for it to finish making the d2v file, and you see the progress of that in the stats window. So I was waiting for VirtualDub to finish making its vdr file, and thinking it wasn't doing anything because the frames all stayed on zero. The guide I read said to leave the window open until it's finished encoding, and for a time I mistakenly thought that meant until the vdr file is finished. Unlike DVD2AVI, no progress was showing, so I thought the file wasn't being made.
That is DVD2AVI indexing the mpg. The equiv I guess would be when you open an ogm or mkv with VirtualDubMod. Strickly speaking it has nothing to do with frameserving. That starts after the indexing is complete and you load the d2v as a source.
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 22:46 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 12:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 05:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
