  1. I've just bought a new camcoder, it works in NTSC, I bought it in Canada... but when I will go to Europe for a long time can I use it anyway? Is there some difficulty with different systems?
    If somebody knows...please!
    Thank you guys
    Sep 2001
    Japan
    Depends on what you would like do with it.
    If you want to play your tapes on TV: should be no problem, as long as your TV is multinorm (most TV in EU are that). If you want to make NTSC DVD from it: no problem.
    You have the signal convert to PAL only if you want to use PAL TV or PAL DVD player.
  3. Thank you a lot man!
    I was already thinking about bring it back...
    Sep 2001
    Japan
    If you have chance to return it, go for it.
    My Sony is a PAL type, but can playback NTSC too. Thus alreday recorded tapes aren't lost.
  5. But I don't think they have a pal camcoder
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If you are using the camcorder to make tapes (or DVD) that you will be taking back to Canada, then keep the NTSC model. The video will play on many/most Euro TV sets.
    If you want to distribute your video only in Europe and taking the PAL video home isn't a priority, then get a PAL model.
    PAL tapes are very difficult to use in Canada.
    http://www.kiva.org/about
    Sep 2001
    Japan
    You should buy one in EU (if you can get your money back). Otherwise - as edDV suggested - keep it.
