I'm currently taking a business course at my High School and I'm planning on recording fifty DVDs or so to try to sell around the area.
I'm going to go with printable media, as I've heard lots of bad things about applying labels on to discs. I've been reading around the forum, and I see that many people say that the printable prodisc dvd-r's are an excellent choice. However, I did notice that this specific brand doesn't appear on the "2nd Grade Media."
Since I'm going to be distributing the discs, the actual quality of the data is my main priority. I'm assuming that Taiyo Yuden printables would be the better choice in my case.
Oh, and what about Silver and White Inkjet surfaces? I thought silver was only for thermal printing, but I've found some websites that say it is for inkjet printing as well...
Thanks in advance,
Tony
Silver Inkjet gives a Hologram effect. I have used the Prodisc in the Past, but started having issues. If it were me I would go with the Taiyo Yuden's. You can get 100 of the TY's for less than 50.00 normally.
http://www.rima.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=R&Category_Code=DMRTY
Which printer will you be using? -
I may end up buying an Epson r200 by year's end.
And what about those Maxell printables? The MXL ID seems to be the highest on the chart, other than the pioneer.
And is there anywhere to see a picture of a printed silver disc?
Either way, thanks for your help.
Cheers,
Tony -
Not sure what Brand it is....
Silver is on the Left.. White on the Right -
Those look pretty good but without actually seeing them it is really hard to see the full detail in any kind of scan or photo, of the silver printable's.
Some things look kind of crappy, but some look kik @$$ depending on what you have printed to them. -
Thanks for your help.
I went ahead and ordered 50 Taiyo Yuden DVD-R 8x hub white inkjet printables.
-Tony
Tayo Yuden Printable and Nero cover design
By alexwick in forum MediaReplies: 5Last Post: 10th Oct 2011, 11:00 -
JVC Taiyo Yuden Blu-ray White Inkjet Printable 4X 25GB BD-R LTH
By xobituaryx in forum MediaReplies: 2Last Post: 17th Jan 2011, 10:25 -
How did the fluke good DVD-Rs from Ritek & Prodisc come about?
By Bix in forum MediaReplies: 3Last Post: 19th Aug 2008, 16:23 -
Prodisc - One foot in the grave
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2008, 23:15 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29
