OK, i´ve during the past days been reading tons of guides and tuts on how to add subtitles. My problem is that i cant get it to work.
i have an avi file and a subtitle file with the same name (extension .srt) and also VobSub installed. I can view the clip with subs in different media players that support it with no problem, VobSub is working fine and the little friendly green arrow shows up in systray.
Now i want to make a dvd outta that avi clip, with subtitles. I dont need the subs to be selectable, permanent is fine. I have followed all the instructions and hints found here: https://www.videohelp.com/forum/viewtopic.php?t=153058 and there´s clearly possible to do it using TmpgEnc Xpress, but i cant get it to work.........I wanted to skip the need of frameserving even if adding subs with it works fine, i just dont want to do that part. Unless its possible to automate it within TmpgEnc Xpress, but that i dont know of.
No subs shows up in preview and no subs in the finalized project
I´ve checked and double checked and triple checked, everything looks just fine, but i cant get it to work
What have i missed here? I know that i´ve done this in the past, on aother XP installation, but now im stumped
				Results 1 to 10 of 10
	TMPGEnc Plus doesn't work properly with directVOBSub in my experience either though.
 ffdshow should work, you might need to reconfigure the output settings though, limiting the colourspaces. For instance with TMPGEnc Plus it wouldn't load with my default settings, but would if I limited it to RGB24. Xpress I think can handle YUY2 input.
	Yes, as far as to my knowledge, i have configured ffdshow to use subtitles, but that didnt help much. To me it seems like Tmpgenc Xpress not picking up the fact that its supposed to show subs, and i cant figure out why......Originally Posted by Baldrick
	Yes i did, i also noticed that a couple of guys reported success with Tmpgenc XpressOriginally Posted by TBoneit
 Believe me when i say so, i´ve been reading a LOT on the subject the last days.......
	I can now confirm that both VobSub and ffdshow seems to be correctly installed and working. Checked them both out and both shows the subs in, for example, Media Player Classic and Windows Media Player and also gives the neat little tray icons  ......So it seems like problem is that Tmpgenc Xpress doesnt pick up the subs, and the question is why, why, why? Getting a bit frustrated here, excuse me for that............. ......So it seems like problem is that Tmpgenc Xpress doesnt pick up the subs, and the question is why, why, why? Getting a bit frustrated here, excuse me for that.............
	I think i have to follow your advice, seems like its the only way to go if i want to use Xpress. Thanks for your help, guys, really appreciated....Originally Posted by celtic_druid
  Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42
  TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23
  BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41
  Permanent subtitles with TMPGEnc Xpress 4.0By b00h in forum EditingReplies: 2Last Post: 18th Dec 2007, 15:43
  difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
