Hello,
I tried to format a -RW disc a few days ago when a power failure occured.
Now my RDR-HX900 does not seem to recognize -R or -RW blank discs (I don't have any +R or +RW left, can not try them out).
Whenever I insert one I get a 'disc error' message, so I can not format them. Hard disk still works fine, as well as previously burnt DVDs. Also, these specific discs used to work fine before the failure.
As anyone come across this before, and what can I do ? Is there a way to re-initialize the RDR-HX900 or somehting ?
Help !
Antoine
Hi, I've now the same problem when I have inserted a blanc disc.
It shows Formatting for a while but then it will restart again.
Can anybody help me -
I am having that problem too. Impossible to dub from HD to DVD. I can still record directly to DVD, so it is not the DVD that has the problem.
Let me know if you find a solution, I am looking on my side.
Thanx -
How old is it. They do apparently have problems with age, but it's likely to be the disks. My GX300 (same essentually) wouldn't read a Philips -RW(x2) disk. I thought is was a problem but tried a JVC -RW (x2) and OK. All +RW have been fine.
Borrow a +RW disk if you can of better still buy as their handy in that they need no finalising to view on a player or PC.
CD-R read error, blank disc
By avextraxjp in forum DVD & Blu-ray WritersReplies: 1Last Post: 25th Jan 2012, 22:58 -
Sony dvd recorder model RDR-GX300 cannot play/record discs
By hdubya in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 02:40 -
C 1300 disc is dirty error on NEW blank dvd's
By rrtbusa in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd May 2010, 08:25 -
Sony RDR HX900 Tuner digital?
By fishnu in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Nov 2008, 16:46 -
Sony RDR-HX900
By munish1000 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Apr 2008, 18:21
