Microsoft .NET Framework 2.0: x86 (KB829019)
update windows site
i think this program needs the above to work
SVCD2DVD is built against .Net 1.1 - so that is the requirement. I have not tested it against 2.0 and will not be able to build against it until I have finished a critical .Net 1.1 project I am working on.
ok i installed 2 anyway so i will test it out
? you have a more uptodate virsion around chris
your clive / brit -
Not at the moment. Snowed under with work deadlines...Originally Posted by britincanada
Let me know how .Net 2 fairs with S2D please. I will release a final stable .net 1.1 version then continue with .net 2... motion menus are in development.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Programs compiled against .net 1.1 will only use the 1.1 libraries. To test against 2.0, you have to compile the program with visual studio 2005. Unless you uninstall 1.1, programs compiled against 1.1 will still work regardless of whether 2.0 is installed.
Which version of microsoft .NET Framework should I keep out of these three?
By mudh in forum ProgrammingReplies: 4Last Post: 10th Oct 2011, 12:51 -
AvsEdit 1.1.1.3 demands .NET Framework 1.1
By Leo48 in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2010, 04:10 -
Hauppauge WinTV and MS Net .Framework
By ionavideo in forum Capturing and VCRReplies: 0Last Post: 2nd Jun 2010, 05:29 -
Net Framework...which version should i install?
By ricardouk in forum ComputerReplies: 4Last Post: 18th Jan 2010, 13:07 -
Help - Can't download .net Framework 2.0
By nhbfan12345 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Aug 2008, 16:30
