  1. How do I convert a DIVX movie with compressed audio to VCD. I tried TMPGENc and i burned it to a cd and the image came out great but all the audio was screwed up. WHY?
  2. Use VirtualDub to save the audio as a wav.
    Use the wav file as your audio source and your avi as the video source.
    I've used this with great success.
    Good luck.
    Figin
  3. U can use AVI2VCD However it will not ocnvert it u will have to decompress the audio in AVI2VCD and it will make even multiplex it for u in pcm audio. SO u will have a avi you can convert in CDUB it will take about 20 minfor 800 megs on a 850 anthlon AMD...... hope it works for u dude
