  1. Problems with DVD::rip. What's wrong? I configured everything to my best understanding. I can rip to .vob but when I try to transcode to xvid (avi) this happens:
    Job 'Transcoding video - title #2, chapter #10, pass 1' failed.
    Executed command: mkdir -m 0775 -p '/mnt/hdb1/Filmer/DVD::rip/Databas-katalog/Gulliver_dvdrip/tmp' && cd /mnt/hdb1/Filmer/DVD::rip/Databas-katalog/Gulliver_dvdrip/tmp && dr_exec transcode -H 10 -a 0 -x vob,null -i /mnt/hdb1/Filmer/DVD::rip/Databas-katalog/Gulliver_dvdrip/vob/002-C010 -w 6000,50 -b 128,0,0 -s 13.908 --a52_drc_off -f 25 -Y 48,8,48,8 -B 12,10,8 -R 1 -y xvid,null -o /dev/null --print_status 20 -J extsub=3:0:0:0:0 && echo DVDRIP_SUCCESS
    Last output was:
    transcode v1.0.0 (C) 2001-2003 Thomas Oestreich, 2003-2004 T. Bitterberg
    libdvdread: Using libdvdcss version 1.2.9 for DVD access
    libdvdread: Couldn't find device name.
    libdvdread: Can't open file VIDEO_TS.IFO.
    tc_memcpy: using sse for memcpy
    [import_null.so] v0.2.0 (2002-01-19) (video) null | (audio) null
    [import_vob.so] v0.6.0 (2003-10-02) (video) MPEG-2 | (audio) MPEG/AC3/PCM | (subtitle)
    [export_null.so] v0.1.2 (2001-08-17) (video) null | (audio) null
    [export_xvid4.so] v0.0.5 (2003-12-05) (video) XviD 1.0.x series (aka API 4.0) | (audio) MPEG/AC3/PCM
    [export_xvid4.so] Neither './xvid4.cfg' nor '~/.transcode/xvid4.cfg'
    [export_xvid4.so] found. Default settings will be used instead.
    [decode_mpeg2.c] libmpeg2 0.4.0b loop decoder
    [decode_mpeg2.c] libmpeg2 acceleration: mmxext
    [encoder.c] Delaying audio (0)
    [transcode] (probe) suggested AV correction -D 0 (0 ms) | AV -23 ms | -23 ms
    [transcode] auto-probing source /mnt/hdb1/Filmer/DVD::rip/Databas-katalog/Gulliver_dvdrip/vob/002-C010 (ok)
    [transcode] V: import format    | MPEG-2  (V=vob|A=null)
    [transcode] V: AV demux/sync    | (1) sync AV at initial MPEG sequence
    [transcode] V: import frame     | 720x576  1.25:1  encoded @ 4:3
    [transcode] V: new aspect ratio | 640x480  1.33:1 (-B)
    [transcode] V: clip frame (->)  | 624x384
    [transcode] V: bits/pixel       | 1.002
    [transcode] V: decoding fps,frc | 25.000,0
    [transcode] V: multi-pass       | (mode=1) writing data (pass 1) to divx4.log
    [transcode] V: Y'CbCr           | YV12/I420
    [transcode] A: import format    | 0x2001  AC3/A52      [48000,16,2]  448 kbps
    [transcode] A: export           | disabled
    [transcode] V: encoding fps,frc | 25.000,3
    [transcode] A: bytes per frame  | 7680 (7680.000000)
    [transcode] A: adjustment       | 0@1000
    [transcode] A: rescale stream   | 13.908
    [transcode] A: AV shift         | -23 ms [ 0 (A) | -23 ms ]
    [transcode] V: IA32/AMD64 accel | sse3 (sse3 sse 3dnowext 3dnow mmxext mmx asm C)
    [transcode] V: video buffer     | 10 @ 720x576
    [filter_extsub.so] 0.3.5 (2003-10-15) DVD subtitle overlay plugin
    [filter_extsub.so] options=3:0:0:0:0
    [filter_extsub.so] extracting subtitle 0x23
    [import_vob.so] tccat -i "/mnt/hdb1/Filmer/DVD::rip/Databas-katalog/Gulliver_dvdrip/vob/002-C010" -t vob -d 0 -S 0 | tcdemux -a 3 -x ps1 -S 0 -M 1 -d 0 | tcextract -t vob -a 0x23 -x ps1 -d 0
    (subproc.c) extracting subtitle stream 3
    [import_vob.so] tccat -i "/mnt/hdb1/Filmer/DVD::rip/Databas-katalog/Gulliver_dvdrip/vob/002-C010" -t vob -d 0 -S 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yv12
    encoding frames [000000-000020],  10.96 fps, EMT: 0:00:00, ( 0| 0| 0)
    encoding frames [000000-000040],  13.65 fps, EMT: 0:00:01, ( 0| 0| 1)
    encoding frames [000000-000060],  15.03 fps, EMT: 0:00:02, ( 1| 0| 0)
    encoding frames [000000-000080],  15.92 fps, EMT: 0:00:03, ( 0| 0| 0)
    encoding frames [000000-000100],  16.34 fps, EMT: 0:00:04, ( 0| 0| 0)
    encoding frames [000000-000120],  16.72 fps, EMT: 0:00:04, ( 0| 0| 0)
    encoding frames [000000-000140],  17.01 fps, EMT: 0:00:05, ( 0| 0| 0)
    unknown ctrl sequence 0x72
    unknown ctrl sequence 0x16
    unknown ctrl sequence 0x54
    unknown ctrl sequence 0x37
    unknown ctrl sequence 0xda
    unknown ctrl sequence 0xc2
    unknown ctrl sequence 0x42
    unknown ctrl sequence 0x44
    unknown ctrl sequence 0x18
    unknown ctrl sequence 0xd0
    unknown ctrl sequence 0x26
    unknown ctrl sequence 0x8
    unknown ctrl sequence 0xf0
    unknown ctrl sequence 0x43
    unknown ctrl sequence 0x48
    unknown ctrl sequence 0x8b
    unknown ctrl sequence 0xa
    unknown ctrl sequence 0x66
    unknown ctrl sequence 0x36
    unknown ctrl sequence 0x3d
    unknown ctrl sequence 0x8c
    unknown ctrl sequence 0xa8
    unknown ctrl sequence 0x8d
    unknown ctrl sequence 0x38
    unknown ctrl sequence 0x9f
    unknown ctrl sequence 0xb0
    unknown ctrl sequence 0x8e
    unknown ctrl sequence 0xf8
    unknown ctrl sequence 0x97
    sh: line 1: 16020 Dödad                   dr_exec transcode -H 10 -a 0 -x vob,null -i /mnt/hdb1/Filmer/DVD::rip/Databas-katalog/Gulliver_dvdrip/vob/002-C010 -w 6000,50 -b 128,0,0 -s 13.908 --a52_drc_off -f 25 -Y 48,8,48,8 -B 12,10,8 -R 1 -y xvid,null -o /dev/null --print_status 20 -J extsub=3:0:0:0:0
    SuSE 9.3 Pro
  2. I have Linux SuSE 9.3 Pro. I installed DVD::rip according to this http://www.exit1.org/dvdrip/doc/install.cipp guide. But instead of using the command # make install I tried to use the command # checkinstall. That didn't work. It was looking for some .tgz-file, which I understand is used under Linux Slackware. But I could run it from the install directory /usr/src/packages/SOURCES/DVD::rip/Video-DVDRip-0.52.6 after adding "." to the $PATH. So I ran it until I got problems transcoding. It didn't matter much which format I wanted to transcode it to. I tried divx4, divx5, xvid, xvid2, xvid3, xvid4, ffmpeg. I always got error messages. Sometimes it ran for a while 10 seconds or so. So I decided to try to install the packman .rpm, which required a newer version of rar. So I installed it then I tried to install the DVD::rip rpm. But it said there was a conflict with AcidRip /usr/lib/perl5/5.8.6/i586-linux-thread-multi/perllocal.pod. So instead I added packman as a new source of installation in (YaST2 the GUI version). That worked, there was no conflict when I checked the dependencies in (YaST2 the GUI version) and the package was installed. Then I started the program again. At first I wasn't root. But the I changed to root and had to reconfigure everything. In the global preferences section I didn't get any red error-messages. Even the CD-Rom burning commands was green. Below are the entries I changed:
    dvd device: /dev/dvd
    dvd mount point: /media/dvdrecorder
    default data base directory: /mnt/hdb1/Filmer/DVD::rip/Databas-katalog
    default directory for .rip project files: /mnt/hdb1/Filmer/DVD::rip/_rip-projekt-katalog
    rar command (for subvob compression): /usr/local/bin/rar
    writer device file: /dev/dvd
    cdrecord device: 0,0,0
    cdrecord command: /usr/X11R6/lib/xcdroast-0.98/bin/xcdrwrap CDRECORD
    After saving them I went over to the other window and opened a new project, loaded the titles and chapters from the DVD, selected title 2 chapter 10 which was 3 minutes and 21 seconds long, selected swedish subtitles, xvid3 and tried to transcode. Transcode runs for a few seconds and then fails with an error message. Again it didn't matter mu which format I chose. avi (divx4, divx5, xvid, xvid2, xvid3, xvid4, ffmpeg), mpeg, ogg. It always exited with error messages after 1-10 seconds. Below is one of them:
    Job 'Transcoding video - title #2, chapter #10, single pass' failed.
    Executed command: mkdir -m 0775 -p '/mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/tmp' && cd /mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/tmp && dr_exec transcode -H 10 -a 0 -x vob -i /mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/vob/002-C010 -w 6000,50 -b 128,0,0 -s 13.908 --a52_drc_off -f 25 -Y 48,8,48,8 -B 12,10,8 -y xvid3 -o /mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/avi/002/Gulliver_DVD_rip-002-C010.avi --print_status 20 -J extsub=3:0:0:0:0 && echo DVDRIP_SUCCESS
    Last output was:
    [export_xvid3.so] v0.3.12 (2003-07-30) (video) XviD nonumber series (aka API 3.0)  | (audio) MPEG/AC3/PCM
    libxvidcore.so: cannot open shared object file: No such file or directoryFailed to init XviD codec[transcode] warning : (encoder.c) video export module error: init failed
    [transcode] auto-probing source /mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/vob/002-C010 (ok)
    [transcode] V: import format    | MPEG-2  (V=vob|A=vob)
    [transcode] A: export format    | 0x55    MPEG layer-3 [48000,16,2]  128 kbps
    [import_vob.so] tccat -i "/mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/vob/002-C010" -t vob -d 0 -S 0 | tcdemux -a 3 -x ps1 -S 0 -M 1 -d 0 | tcextract -t vob -a 0x23 -x ps1 -d 0
    [import_vob.so] tccat -i "/mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/vob/002-C010" -t vob -d 0 -S 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x ac3 -d 0 | tcdecode -x a52 -d 0 -A 1
    [import_vob.so] tccat -i "/mnt/hdb1/Filmer/DVD_rip/Databas-katalog/Gulliver_DVD_rip/vob/002-C010" -t vob -d 0 -S 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yv12
    [transcode] critical: failed to init encoder
    Is there a problem with having colons in the filename "DVD::rip". When I installed all the rpms needed for dvd::rip, from the commandline, the packages was in subdirectories named "DVD::rip".
    Thanks in advance, Lars
    SuSE 9.3 Pro
  3. The solution was to use transcode 0.6.14 instead of the buggy transcode 1.0.0
    SuSE 9.3 Pro
  4. Member oldcpu's Avatar
    Aug 2005
    Europe
    Thanks for posting your solution.
