I want to buy a DVD player that has either 720p or 1080i output via HDMI. My HDTV has a DVI connector so I need somehow to adapt the player output to the HDTV input.
Results 1 to 14 of 14
Thanks. Another question is if I use the adaptor will the HDCP be bypassed so the movie will display on my HDTV with DVI input?
Originally Posted by Bob W
If this is a current standard def DVD player, it probably doesn't require a HDCP monitor unless it says it does..Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I was hoping that something like this might work where you could somehow bypass the HDCP but it's a complete secure quality assurance environment. -
Here's a much less expensive source for HDMI-DVI adpaters and cables...
http://www.pccable.com/ -
I haven't heard anyone complaining about this yet with standard DVD players. HD DVD players will require HDCP.Recommends: Kiva.org - Loans that change lives.
I sense deja vu. -
Scott -
Originally Posted by Cornucopia
With my limited experience with HDMI sending boxes (Scientific Atlantic 8xxx HD cable boxes, etc.), they seem to default to cutting S/PDIF audio (AC-3) when HDMI video is engaged. This is a bad omen. It usually takes a call to support to find a way to restore a parallel HDMI (video) and S/PDIF (audio) path. Maybe I'm paranoid but I suspect this will be the default when HDCP becomes common reality. That is, surround audio will be forced into the HDMI path.
If that is the case, we may be forced to buy all new audio receiver-decoders as well as all new HDMI HDTV sets.Recommends: Kiva.org - Loans that change lives.
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 00:15 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Aug 2009, 23:14
