Is there a switch box for component cables? My HDTV only have one component input on the back. I'm looking for a switch box that will allow me at least three component inputs and switch between the source. I don't want to plug and unplug my DVD everytime I want to play from my camecorder and other source. If there is a switch box for this, please link me to the site or a review. Thanks!
Yep.
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=353299&...ughType=search
There are others... Google a bit and you'll find them.
W -
Most Walmarts carry this one. I've seen a similar one with a Philips label.
http://www.walmart.com/catalog/product.do?dest=9999999997&product_id=3312963&sourceid=...30660804302498
http://www.audiooutfitter.com/store/VH911.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I know that you are going to have doubts but you can solve your problem for $20 at radio shack:
http://www.radioshack.com/product/index.jsp?productId=2049645&cp=&kw=composite+video+s...entPage=search
Give it a try and if you are unhappy take it back. Hook it up red-red, white-blue, and green-yellow.
Don't worry that this is designed for composite rather than component. I have been using one for over a year with no signal degradation to my eyes.
Only warning is that you need high quality component cables as I did have signal dropout when using cheap cables.
A suggestion for cabling (also remarkably inexpensive) would be:
http://stores.ebay.com/Beyond-Computers_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
These cables are an excellent value imho. -
Walmart usually carries $9 component analog cables (use for 480i) and $20 double shielded component analog cables (use for 480p, 720p, 1080i).
I use the same RS switch that Eyedoctor2 mentions. Works great for me. The hardest thing is to find short enough component cables. Most seem to be 36" and they take up a lot of extra room.
Why not make your own???All you need is a 4017 ,two 4093's and one transisistor per switched cvbs op that you need...give me an email and you can have the schematic
regards mike
A-B Switch Box?
By MourningStar in forum Newbie / General discussionsReplies: 8Last Post: 9th Mar 2010, 19:41 -
Question about AV Switch Box
By the_importer in forum Off topicReplies: 9Last Post: 28th Sep 2009, 15:41 -
Can you get hi-def component splitters or switch boxes?
By eggedd2k in forum DVB / IPTVReplies: 4Last Post: 7th Dec 2007, 09:10 -
Do you use a switch box to add units to your tv/entertainment center?
By yoda313 in forum PollsReplies: 24Last Post: 6th Dec 2007, 06:14 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23
