I have tv shows on the pc as avi's, (some divx, some xvid), im looking for the best way to make them into mpg files, compatible with tmpgenc dvd author program. I have followed a few guides on here using tmpgenc 2.5 but always end up with strange results, like a 29 minute program showing 16 minutes into the program with only 16% of the encoding completed - surely this should be around 55-60%? Im putting max 6 episodes on a dvd-r and calculated bitrate of 3198, at 16% completed the filesize was around half a gig! G spot says the avi file is valid and at least 3 encoders are installed.
Any other suggestions as to where Im going wrong?
Stevie
Stevie
Glasgow -
probably mp3 vbr audio and tmpgenc does not like it, convert it to wav
www.videohelp.com/tmpgenc#problems
or use something else like the old free divxtodvd and then import the dvd in tmpgenc dvd author. -
If in doubt, Google it.
Maybe you can have a try on WinAVI Video Converter. It can convert avi to mpg as you mentioned!
You may be in breach of the forum rules and your account has been suspended while we investigate claims of you being a possible shill for WinAvi. Thank you for your co-operation.
/ Moderator offline
Ripping, converting audio and then authoring the DVD
By vishwanath in forum Authoring (DVD)Replies: 10Last Post: 13th Jun 2011, 22:58 -
DVD to mpg converting....
By jay_lubb in forum Newbie / General discussionsReplies: 6Last Post: 31st Aug 2010, 05:31 -
Converting AAC to AC3 (for DVD authoring), losing audio
By senorroboto2k5 in forum AudioReplies: 3Last Post: 16th Feb 2010, 18:03 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 13:08
