Hey everyone,
I've searched the net for what I need, and indeed I thought I'd found it a couple of times, but with no avail. I was wondering if you guys could help, and this is probably relatively simple but, how the hell do you set DVD Rebuilder 1.1 Pro with CCE SP 2.7 to output to 4,400mb size? I've changed about TargetSector values etc. but it's always either too big or too small... I've even taken the percentage size change I need, divided the current TargetSectors value by 100 and multiplying it by the other value and using the result, but the change is always way off... I just want it to output to around 4,400mb every time.
Regards,
KD.
I'm no failure! I've just found 57 ways that don't work...
Ok, I'd thought as much but was hoping otherwise. Well, the program is fairly accurate. I've done a few DVD's in experimentation and the output dosn't usually change by more than 0.05GB. Can anyone tell me what to set it to so that I get an output say around 4380MB allowing that it may go 20mb in either direction?
I'm no failure! I've just found 57 ways that don't work... -
Use this formula, courtesy of wmansir on Doom9:
or, to simplify, 517685 x Target Size in GB = Target SectorsDefault Sectors (2236400)/ Default size (4.32GB) X Target Size(in GB) = Target Sectors
4380 MB = 4.277 GB.
This gives the result of 2214140 sectors. -
I'll give that a try. Thanks
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 09:10 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 04:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 09:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 11:56
