hi good day to all,
i read somewhere that it's possible to author dvd using mpeg1 did anyone of you guys tried it if yes can you show me how to do it appreciate the help thanks
Look at What is DVD (top left of the menu) to see the allowable specs for mpeg-1 usage. Basically you are resticted to VCD resolution (read low res), but at a slightly higher bitrate. You can fit up to around 7 hours on a single sided/layer disk at this res. If you already have VCD source material, don't re-encode, just up the sample rate of the audio to DVD compliance 48khz) and author.
Read my blog here.
Yes. Encode as VCD mpg, but use 48 kHz audio sample rate (instead of VCD std 44.1).
If you already have VCD compliant mpg, both DVD-Lab (pro only?) and TMPGEnc DVD Author takes care of the audio upsampling for you, when authoring.
/Mats
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Poor DVD quality: Computer screen recorded to DVD (mpeg1)
By MC123 in forum MacReplies: 6Last Post: 3rd Feb 2008, 15:33 -
dvd to mpeg1
By videogirl in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 19:26 -
Mpeg1 to DVD, problems abound - help, please
By Neisse in forum Video ConversionReplies: 6Last Post: 8th Jul 2007, 17:23
