Trying to convert this VIDEO_TS to AVI DivX and get a superb video with no audio.
However the audio information (ac3, 48000Hz, 192 kbps) is recognized in the Source format field.
And the correct Audio track is selected under the Audio tab.
If I try play, there is no sound.
However if I play MPlayer separately the sound is here.
This is the Process information:
Encoding started on Mon Nov 7 20:26:09 PST 2005
MEncoder dev-CVS-050814-13:46-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
libdvdread: Couldn't find device name.
Reading disc structure, please wait...
There are 1 titles on this DVD.
There are 13 chapters in this DVD title.
There are 1 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x0 - 0xefa87800
MPEG-PS file format detected.
Too many video packets in the buffer: (4096 in 8260508 bytes).
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
MPEG: No audio stream found -> no sound.
VIDEO: MPEG2 720x480 (aspect 2) 29.970 fps 8000.0 kbps (1000.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening video filter: [expand osd=1]
The selected video_out device is incompatible with this codec.
Also try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred csp: Mpeg PES)
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG-1 or 2 (libmpeg2))
Forcing output fourcc to 58564944 [XVID]
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
videocodec: libavcodec (640x352 fourcc=58564944 [XVID])
1 duplicate frame(s)!
demux_mpg: 24000/1001fps progressive NTSC content detected, switching framerate.
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 799.521 kbit/s (99940 bps) size: 567121045 bytes 5674.608 secs 136064 frames
Encoding completed on Mon Nov 7 21:03:37 PST 2005
Any clue ?
I'm experiencing quite the same problem with all the movies I ripped using MacTheRipper : ffmpegX doesn't "detect" the VIDEO_TS file when I tell the program to select it. However, when I press the "play" button, the movie plays — but no sound.
Did you find an answer to this problem, since you posted this ? Otherwise, could anybody give me some piece of advice ?
Thanks !The road of excess leads to the palace of wisdom. - W.B. -
I'm a poster on HB forum too.
Your problem has been reported several time.
It never happened to me.
But I know there is a fix for G3 users.
Are you one of them ?
This is the forum link, it's quite empty now because the site crashed and it just opened again a few days ago:
http://handbrake.m0k.org/forum/
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Exception: Audio is not found [AutoGK]
By corn in forum DVD RippingReplies: 2Last Post: 3rd Sep 2009, 00:57 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 00:59 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
